Nexus 4 does not "lock" when display shuts down automatically
CaptainNexis
5
Hey everybody !
Well, i noticed those last days that when my phone shuts down without pressing the "Power" button (Auto display shut-down after 60 seconds) and then i press the power button, it's not locked. I mean, i immediately arrive on my homescreen and not my lockscreen, so it's not actually locked. It might be problematic in public places. If i shut it down manually by pressing the power button, everything's normal, lockscreen appears normally.
So does anybody here have the same problem/knows how to fix it ?
its not a issue. its a settings.
settings-->security-->Automatically lock-->Immediately
the reason why the power button instantly lock is because of another settings
settings-->security-->power button instantly lock is checked
Thanks a lot!
I did not find those settings first because i did not set any specific security, those settings only appear if you set up a PIN code or a password...
But anyway, thanks once again, problem solved.
Thanks a lot!
u r welcome.
dumpsterrentals102
