nexus 4 problem
Jul 28, 2013
8
i had a problem yesterday , my n4 ran out of battery and its still not want to boot up . I plug it into the wall charger and a white battery icon appears with no animation. If i put it in recovery mode it boot but get stuck on the google logo screen :p! do you know whats the problem ?
Thank you
hope somebody ill reply :p
Thank you
Did you try charging it and leaving it be for half hour to an hour? If the battery is at 0% and you plug it into the charger the phone may not let you use it or do anything until there is a minimal charge.
hey thanks for the reply ! my phone has been charging for aboute 4-5 hours last night ! I think it might be something else
You are welcome and sorry to hear about your troubles. Try unplugging it from the charger and holding in the power button - literally may have to for 60 seconds.
Hopefully it powers down then restarts normally. Fingers are crossed for you.
Let us know if this worked.
Sent from my Nexus 4 running Android 4.3 & using Tapatalk 4
I dont think its a battery problem. Your phone doesnt seem to be booting. Are you rooted or anything?
mostafamu
