Nexus 4 stuck on boot screen after installing cyanogenmod PLEASE HELP
David Thorne1
I rooted my phone yesterday and started using franco kernel and decided to flash a custom ROM. I naturally started with Cyanogenmod as it is very popular and seems to be the most stable. When i flashed my phone via my mac it seemed to go well, until It became stuck on the boot screen. Ive tried factory reset and wiping the cache and booting; still boot screen. I did the wipe again and tried flashing it a second time, again boot screen. Im praying that i didnt brick my phone. Any suggestions?
You have a Nexus 4, so no need to worry about bricking it :). If you haven't fixed this issue try the following:
Go back into recovery and wipe data, system, cache, boot. Flash the CM ROM then Gapps. Reboot and wait a few minutes and let us know if it boots.
If it doesn't, restore the backup if one was made before you started to tinker. If you didn't, you can try downloading another ROM or the CM ROM again via computer and transfer to the device with USB mounted through recovery.
Finally, if nothing is allowing you to successfully flash the ROM you can try restoring the factory image. Use this guide to get you the factory image restored: http://forums.androidcentral.com/ne...3923-guide-nexus-4-factory-image-restore.html
Let us know if you have questions.
I'm curious, did you ever get your Nexus 4 up and running? If not, let us know and maybe we can get a working solution for you :).
Hopluikla
