Nexus 4 Waterproof case
David Neo
I can't seems to find a Nexus 4 waterproof case , i want it like Lifeproof case do you guys have any ? Could you share with me thank !
Same ! I was damn pissed off that i'm keep getting ZIP LOCK BAG result ! why no case maker would want to make a waterproof case for nexus 4 !
Not familiar with the existing ones for other phones, but I imaging it would have to wrap around on to some of the screen space to truly seal it. With the way these screens reach right to the edge I think there would be a hard compromise of screen usage and actual water proof seal?
Pelican Case...
pelican-flashlights_2264_197427163
It's the most hardcore travel case. I've got one for kayaking. Seal it up - throw it at the water and it will bob right back to the surface. Open it up - everything is dry and cozy.
Here's your size - just pad it out with some foam shims for a custom fit: Pelican?Products?1040?Micro Case
Lifeproofs are pretty pricey, anywho I know Otterbox does a waterproof for iphones.
Just wish there as one specifically for Nexus 4's
These guys have the Pelican 1040 for just $16.45 + the matching, sized to fit the case foam block for $4.99. The foam is pre-scored in tiny squares so you can "pluck" out the middle of the foam block to cradle your N4...
Pelican 1040 Micro Case 1040-025-100 B&H Photo Video
Check out the demo videos on their page!!!!!
One of the best prices I can find for this case+foam and you could custom fit the foam for most any phone. Interior dimensions of the 1040 are 6.5 x 3.87 x 1.75" (16.51 x 9.83 x 4.4cm) (LxWxD)...
Fast order fill and shipping as well...
Ordered two of each (1040 case + Pick n Pluck foam) right after posting. $50.78 shipped UPS ground and it is scheduled to arrive Thu 06-20-13. :D
You shouldn't need one. The average phone survives several spills if you clean quick
Sent from my Nexus 4 using Tapatalk 4 Beta
And when you need your phone strapped to the deck while you're out here?
images
No amount of wiping will take care of that...
I found this product while looking for a phone bracket for our bikes.
I currently own a few Ram Mount holder/brackets for our marine handheld GPS's and their versatility and sturdiness are outstanding.
Ram Mount product:
AQUA BOX? Pro 20
RAM Large Size AQUA BOX? Pro 20
A thin, optically clear membrane provides tactile screen operation access to all side buttons on the phone while in the case.
Just bought one for my N4 (the video on their website sold me) but I will comment further when received.
Ashok Dharshan
