Nexus 5 Battery life, best app for saving battery?
App_London
Hi All!
First post. :)
My Nexus 5 battery is terrible. I have stopped syncing my phone which helps..
It seems that the battery saving apps I use are useless. In fact I have read that some task killer apps can make tings worse. When I click on settings>apps>running it still shows them in the background. One app I favor using is Evernote but I feel the size of it really affects my phone.
Is there any way around this??
Also is there a way I can get emails alerts on my phone on time without having to sync? Possibly a app that texts me every time I get email ( possibly iffft might work).
Thanks in advance for your help and having reading this.
I use Juice Defender in work and set it to only switch on data when I switch the screen on.
Through a 12 hour shift I may drop about 50% of charge with occasional viewing.
Additionally I use Phone Weaver to enable a work mode which switches off wifi, reduces sounds and dims the screen, particularly on nights. I also reduce the screen timeout using this too.
Also discovered Clean Master which runs a memory clean every time I switch the screen on... Also very handy.
Plus, I also have Evernote installed and never have an issue with it when I am using the above.
Sent from my Nexus 5 using Tapatalk
After trying all sorts of newer battery apps since gettting my Nexus 5, turns out tried and true Juice Defender works best along with Greenify.
Can you post a screenshot of your battery page so we can see what's going?
Have you tried doing a factory reset and wiping the cache partition?
Sent from my Nexus 5 via Android Central App
