NEXUS 5 do not connect to wifi nor bluetooth
Giovanni Lauria
Hi all,
all of a sudden my nexus 5 lost the wifi.
Getting "Activating..." but nothing happened.
Thought it was a bug I went back to a newer version 5.1.1.
Same issue.
Downgraded to 4.4.4 and 4.4 same issue.
Is there some "Permanent" Config file where info on the wifi adapter are stored across Android Releases and installations ?
Hi all,
Same issue.
Welcome to the forums! I'm not sure that you resolved this problem, but if not, try resetting your wireless router. If that doesn't work then try clearing cache through recovery. Be sure to clear cache only, not data.
It sounds to me that you might have a hardware issue instead of a software issue which is a lot worse. Considering you switched to different Android versions and the same error occurred.
seobinson
