Nexus 5 - Faulty Battery Sensor and Android Update
chriswilkinson69
Hi,
Recently my Nexus 5 developed a fault on the motherboard and it now shows the battery level permanently at 0%. Despite this it is working perfectly well on the whole - it is just the sensor that is faulty.
However when I try to update the system using the OTA update it displays the message "Battery too low to install system update.....". Is there any way that I can install an Android update despite this fault?
My main concern is that I won't be able to install Android N when it becomes available.
Thanks.
we are not sure even if google will release and Roll out an official OTA Android N update for nexus 5 as it's out-dated now.
are you sure it'll?
try calibrating your battery.
if it doesn't work do a factory reset.
Opoliraka
