Nexus 5 Help
Bilal ArQob
Active member
Jul 15, 2014
28
- My Nexus 5 screen lock off by it self while I using the device! after 1 or 2 sec .. (not always)
- The music player ( SoundCloud, TTPod .. etc ) move to the next song auto without the song finish!
What exactly are you doing when Screen Lock activates itself? Did you try to turn off the screen locking in the settings? What does it do then?
Which music player are you using?
Do you have some security software like "Comodo" installed? Because maybe you have been subjected to malware of some kind?
If everything else fails, reset to factory settings. But maybe some other people have better ideas here.
1. Settings--->Display--->Sleep--->After 2 Minutes of Inactivity
2. Switch to a different Music Player
good luck.
mostafamu
