- Mar 6, 2013
- 9
- 0
- 0
I can't nail down why I can only get about 3-4 hours of screen time and 10 hours of total off-AC time on my new Nexus 5. Screen generally accounts for 40% of battery usage, followed by Android System at 12% and Android OS at 8%.
I can't figure out what I'm doing, so I'll just list everything I did.
I downloaded the KitKat 4.4.2 factory image from Google. I booted my Nexus into fast boot, then used Terminal (on a Mac) and fast boot erased system, boot, user data, cache, boot loader, and recovery. I then flashed (from the factory image) system, boot, user data, boot loader, and radio. I formatted cache and flashed CWM Recovery. I immediately boot into recovery and flash the SuperSU zip as an ADB side load.
I then start the phone for the first time, go through the setup process, and add my Google Account. I disable all sync options except for Contacts, Google Play Music, Gmail, Google+ Photos, and Google Play Books. I then set Photos backup to only sync when plugged in and on WiFi, and disable systemwide backup.
I then update all my system apps, install Snapchat, Flow (reddit client), AdAway, and Tasks while disabling some useless apps.
I then go to Developer Tools and switch to ART, then let the phone reboot.
This is my phone in its essentially ready to use state. I experience generally mediocre battery life, with the Screen (40%), Android System (12%), and Android OS (8%) accounting for significant battery usage. The Nexus gets warm or even semi-hot when merely web browsing on WiFi or using lightweight apps (non-media apps).
This is driving me insane. The general online consensus is that 4.4.2 has terrible battery life compared to 4.4, but can someone hopefully shed some light on what I'm doing wrong? Thanks very much for reading through all this stuff.
