Nexus 6P - Android 6.0.1 - Raise volume above recommended level notification?
  • Start date Start date
A
AC Question
Hi,
It's been happening for months that I frequently get this notification, this occurs randomly -- whenever I'm listening to music or w/e, my volume automatically and the notification is shown.
"Raise volume above recommended level?
Listening at high volume for.....blah blah blah"
Re: Nexus 6P - Android 6.0.1 - Raise volume above recommended level notification
Are you saying that this notification pops up when you're not fiddling with the volume?
I've only seen it when I'm raising the volume level.
I've never seen that notification, but I've heard of it before. Are these US based 6P's or no?
It is more than likely that all phones today comply with European Volume regulations ( European Commission - PRESS RELEASES - Press release - Questions and answers on the mandate for new safety standards for personal music players ).
From previous threads about other Nexus phones, my best guess is that you only get this warning if you are using low-impedance (in the 16 - 20 ohm range) wired headphones/earbuds. Briefly, the lower the impedance, the greater the volume output for a given voltage input; thus, low-impedance earbuds are capable of substantially louder output than high-impedance models (32 - 40 ohns).
See if you can ascertain the impedance rating of your current earbuds, then try a pair with a higher rating and see if the warnings go away.
alexanderjames
