Nexus 6P - Divide and Nine: Configuration from managing application required.?
  • Start date Start date
A
AC Question
When installing Divide and/or Nine on a user's Nexus 6P with OS 6.x, I get the error when attempting to open either of these apps. They're used to create a separate environment for work productivity apps (email, calendar, etc). Obviously there's a setting or missing app that is causing Divide and Nine to fail. Does anyone know how to fix it so I can get my work email back on my phone?
Note: A secure environment like Divide, Nine and Touchdown is required by work policies.
Thank you.
-Cory
Re: Divide and Nine: "Configuration from managing application required."
If apps are not listed thru Google App store, try a settings change.
Go to Settings - Security - Unknown Sources. Then toggle switch.
Be sure you trust where the apps come from and that they are valid and trust worthy.
Re: Divide and Nine: Configuration from managing application required.?
Thanks for the reply, Hawgee. Both apps were downloaded from the Google Play Store, so we're totally legitimate.
-Cory
I use Nine all the time on my 6P without issue. I did have a license issue when I first switched over but it resolved itself after a couple days.
"Configuration from managing app required" sounds like an issue with the way your work exchange server is configured, not your app. I use Nine as well for work exchange email and have never encountered this problem. I suggest asking your IT department about it and see what they can do. If you are IT, consider looking at your active sync settings and policies connected to your account to make sure active sync is enabled. A policy setting on your company's exchange server may also be restricting active sync access to these apps.
Thanks for all the assistance, people. I was never able to get Divide to working, but after installing Nine a second time, it started working. I checked app settings, security settings, active sync settings, and so on. Shrug. Call it a fluke.
-Cory
cinemacritic
