Nexus 6P Verizon simultaneous voice and wifi hotspot, are there any fixes?
ShiftySheik
6
Nexus 6P Verizon. I can use the phone without losing my data connection however if wifi hotspot is enabled I lose my data connection when on the phone. Is there a fix for this?
Re: Nexus 6P Verizon simultaneous voice and wifi hotspot
Do you have advanced calling feature enabled on your account and on the phone? Does it keep lte on calls?
Yes, Enhanced 4G LTE Mode is on. I confirmed this with VZW support. However, when on a call that setting is grayed out. After ending a call I can toggle Enhanced 4G LTE Mode setting on or off. The wifi does not work when on a call nor does the data connection on the Nexus 6P.
Update. It's fixed. Must have been the phone call to VZW support to have them turn on advanced calling feature for my number. Seems that it did not take affect right away. I also tried starting the wifi hotspot with pdanet/FoxFi and that worked as well while using the phone. Thanks for the help.
KevinInKy
