Nexus 7 Falcon widget problem
lEssence
70
I'm having a small issue with the falcon widget.
Im running 4.4.2 and I downloaded the Google now launcher
( so then I'm able to swipe left for Google now )
When I'm using the Google now launcher the falcon widget is no where to be found. The app is in the app drawer but I can't activate the widget from there .
When I run the stock launcher the widget is their under the widget section.
Anyone have a solution? as I prefer using the Google Now launcher.
Thank you in advance !
Press and hold on an empty space in GNL. Once the three options appear, tap "widgets". From there, find the Falcon widget, tap and hold it, and drag it to where you want it to be. That should do it.
Sent from my iPod touch
It should look like this:
Sent from my SAMSUNG-SGH-I727 using Tapatalk
yettispagetti23
