Nexus 7 "My Library" Not displaying album art
Solution
Clear the data from google play
First off, make sure that your albums are correctly labeled. If you don’t take this step, the others won’t matter.
Then, download a “album art grabber” app from Google Play. Their are plenty of free ones out there.
Open the album art grabber, and “grab” you’re album art covers (this can take quite some time).
After the app finds all your album art, go to Settings>Apps>All >Music.or Google Play Music
Hit the “clear data” button. This will wipe out everything in your Google Music app (playlists, settings, etc).
Now, open up the music app.
It will scan your device for music, and this time it will find it with its related album artwork.
Thanks test101010. That worked for me.
So I am having an issue where the "My Library" page doesn't display album art for songs I imported from iTunes.
The album art shows when I play the song, but just the generic art shows in the my library which really bothers me.
I tried album art grabber and no luck.
Any ideas???
Solution: "Uninstall updates". First, clear app cache then, clear app data then, stop program then, uninstall updates and confirm you want to install factory version. Restart the app, it will scan for music and album covers will re-populate the "My Library" menu.
HourFromNow
