Nexus 7 Newbie - help need re Lock screen - please
Niloc35
7
When first using my Nexus 7, I decided to setup a password on the lock screen, which already displayed an analogue clock.
Thinking I needed to configure the clock for the UK time-zone, I unintentionally added another analogue clock!
Now I just can't get rid of it! I tried dragging to the X Remove icon, & it does disappear, but the next time I access my lock screen, it's back!
Anyone know of a simple way? Can both be removed permanently, & replaced with something else?
Many thanks if you can help.
Niloc35
if you meant another time on the clock on lockscreen then open clock app--> there will be a location map icon. click on it and remove the other location.
if you want to remove clock from lock screen long press the clock on the lockscreen. a remove button will appear on top.
move it to remove and it will be gone.
Zcesbidend
