Nexus 7: Screen Shots
Re: Screen Shots
Re: Screen Shots
Stock launcher.
HD Widgets.
Re: Screen Shots
Man everytime I see HD widgets, I am tempted to pull the trigger and buy it
Re: Screen Shots
Sent from my Google Nexus 7 running aokp 4.1.2, because there is no PacMan rom for the nexus :(
Re: Screen Shots
What's the difference between HD Widgets and Beautiful Widgets? I have the latter, and want to know if there is a reason to purchase HD.
^That.
HD widgets is definitely the way to go my friend. I don't buy many apps. I usually try to download the light/free versions but this is one app that I didn't hesitate to purchase.
Re: Screen Shots
Not sure about the details as to which one is better. For me, aesthetics were the driving force behind making the purchase HDW. I found them to be more functional and useful for myself. Plus with the quality of the nexus screen they make your tablet look really nice.
Re: Screen Shots
Thanks for the response, I purchased the BW when I still had my Droid, I have since moved onto the iPhone, but BW works and is installed on my N7.......honestly though I don't find myself using the widgets that much......so just not sure if the HD is a future purchase for me or not.
Re: Screen Shots
I downloaded widgetsoid. It's free and lets me make my own. :):thumbup: that plus paranoid android ROM, and it's heaven.
**GO MAKE SOMETHING HAPPEN - I.Guy*
sent from my N7, using Tapatalk HD
Re: Screen Shots
Nova Prime
Glass Rounds
All widgets except for the dock.
Image from Google
Sent from my Nexus 7 using Tapatalk HD
Re: Screen Shots
I had that problem for the longest time too. Try think hit the power button and the lower half(the part that lowers the volume) and the same time. If I hit the upper portion of the volume button I just end up raising the volume and no screen . Hope this helps.
Re: Screen Shots
I wonder if there is any app that allows u to be able to change your orientation by pressing your volume keys
Re: Screen Shots
I might check them out
- - - Updated - - -
This is very nice!!!!!!
Nova Prime
Glass Rounds
Image from Google
http://img.tapatalk.com/d/13/01/16/uzese8u4.jpg
http://img.tapatalk.com/d/13/01/16/5umy2ary.jpg
Re: Screen Shots
Sent from my Asus Nexus 7
Re: Screen Shots
Here's my cluttery homepage
Aruz530
