Nexus motorcycle mount
Live2ride883
1,009
84
Has anyone found a secure/safe way to mount the nexus on a motorcycle? I just picked up a softail and would love to be able to mount my Nexus on the handle bars so I can use the navigation.
My best guess is you'll have to buy a mount and somehow make yourself a mount for your bike. It wouldn't be good for it to fly off. That's for sure. Not a good way to rule the air.
dropped from LiquidNexus via TapaTalk
I dont ride anymore but if i was, i wouldve mount the nexus in a ram waterproof box and used bluetooth headset that wraps around your neck, the one that uses earbuds, forgot the model
Here's what I came up with last night, just using stuff I had around the house.
I took my Verizon vehicle mount and chopped the basket off where the phone clips in. Then I cut the top off of an old bicycle mount and glued them together with gorilla glue and clamped them together over night.
This is gonna be a temporary mount to use until I get my drag bars and risers later this summer (birthday).
Depending on how it looks on the bike I may not even use it.
I'm looking for a similar solution, and found a couple of possibilities that I thought I would share:
Premade: Bike Bicycle Mount Holder For Samsung Galaxy Nexus Prime i9250 | eBay
Another "make your own" solution (youtube):
http://www.youtube.com/watch?v=uxrxTvfpgfo
and a couple of waterproof choices:
(review for the medium says a Razr wouldn't fit without pressing side buttons; I think the Gnex is about the same width):
RAM Large Size AQUA BOX
RAM Medium Size AQUA BOX
..I haven't yet decided on which solution I will use. :confused:
hiredbyskill
