Nexus S restarting during calls
They need to roll it out ASAP. I had the phone reset 3 times in a row the 2nd week of ownership. I factory reset and had no problems until 2 days ago and since then I've had 6 resets. Its ridiculous.
I'm going to do another factory reset tonight but first I want to make sure I wont lose any of the paid apps I have on the phone. They store to my Gmail account, right?
Correct. You can reinstall paid apps; they are linked to the GMail account you used. Your app's data will be lost, though. So your high score in Fruit Ninja will be lost :) (Unless the app lets you back it up, of course).
Yeah, if you are anything like me, and have ten-gazillion apps, make sure you are near your wifi connection when you do the wipe, as it will start to download them all for you automatically. (It will also restore your Wifi settings).
Sounds like the 2.3.3 update should fix this issue:
Nexus S Random reboots - Google Mobile Help
I'm very glad we can finally provide an OTA update to address the reboot issue. The team worked really hard to get this and a bunch of other stuff fixed (while adding some cool new NFC capabilities). Thanks for gutting this one out with us, your patience is very much appreciated.
If you experience any problems with Android 2.3.3, please post the issue to a separate thread.
-Ry Guy
i only had this problem a few times but im glad its over with. im very happy with how fast updates get pushed to the nexus s. i had 1 real update for my eris when i had that at launch
So did the 2.3.3 update fix the issue with "the amazing rebooting NS"? I still have no OTA 2.3.3. update.
My NS has started rebooting, 6 times in the last 24hrs. No new software installed.
Haven't had any reboots since I manually installed the 2.3.3. update.
There is a small issue with the 3G icon sometimes appearing when the Wifi is connected but otherwise I'm happy with the update.
mhuk01
