Night Battery Drain
Grim Reaper
8
Hi everyone -
I have a stock Note 5 and all of a sudden for the last couple days I have been seeing crazy battery drain during the night. Last night I went to sleep with it at 100% and when I got up 10 hours later, it was 62%.
I have linked a screenshot of the battery usage. Can anyone help me fix this?
Try clearing the device cache by following these steps: https://support.t-mobile.com/docs/DOC-27659
If that doesn't work, consider a factory reset (backup/sync before hand) then keep an eye on battery usage/drain. You can also try replacing the battery with a new one and see if that helps. The original battery may be depleting faster due to age, which is a problem in all cell phone batteries.
JediahBlades
