No battery usage data
JamieRM
4
I have a smartphone running on Android pie the go edition. After getting the phone and using it for quite some time am not able to view battery stats. Nothing shows up when I go to the battery stats. I have wiped cache and still nothing happens. It is the way the Go OS is built that causes it not to populate battery usage or is there wla way to do this. Mind you this is my second Android Go device. The first running on Android Go Oreo still doesn't show battery usage stats
Sorry it took me sometime to see the registration requests:
Same question as before now that am registered
I have a smartphone running on Android pie the go edition. After getting the phone and using it for quite some time am not able to view battery stats. Nothing shows up when I go to the battery stats. I have wiped cache and still nothing happens. It is the way the Go OS is built that causes it not to populate battery usage or is there way to do this. Mind you this is my second Android Go device. The first running on Android Go Oreo still doesn't show battery usage stats
Hi Welcome Jamie!
Put the phone in safe mode to see if battery stats work ?
KidColoringPage
