No settings to adjust camera such as mode, sounds etc. I can't zoom or turn off the "click" help
  • Start date Start date
A
AC Question
I can't find my camera app settings on my galaxy s5.
Want to turn off the camera click, and be able to zoom.help!
Re: No settings to adjust camera such as mode, sounds etc. I can't zoom or turn off the "click" help
Assuming you are not just having fun with us and this is a real question, running 6.01 press on the gear. In older versions it still should be a gear or the three dots menu bar. one or the other is found when you launch the camera app. Again this assumes you are using the stock app.
Next time you post include model and at least android version
SM-G900V
Android 6.01
Verizon
Mine doesn't zoom. You take the picture, then zoom in in Gallery.
SM-G900V
Android 6.0.1
Verizon
You probably cannot turn off the camera click, that is there by law in many areas to prevent people from taking "candid" shots of unsuspecting people (ie bathroom, changing rooms, etc.)
To use the zoom feature on your camera, either use the volume controls to zoom in or out or you can also "pinch to zoom" - place two fingers (like your thumb and forefinger) together on the screen and slowly move them apart. Your camera will zoom in.
pramanj96
