- Oct 27, 2016
- 3
- 0
- 0
Quite often when I make outgoing calls on my S5 Active, I can't hear anything for the first 30 to 35 seconds and then the volume kicks in. The people on the other end can hear me. It only seems to happen when I'm not using bluetooth. I have tried turning bluetooth off, many reboots, and a full master reset. It only seems to happen since upgrading to Marshmallow. I have it connected to my Gear fit most of the time but I don't think that does anything since I've tested it without it connected. Incoming calls are always fine. I suspect an app might be interfering but not sure. Occassionally when I try to hang up after it has been attempting to make a call, it 'hangs' and does not respond and then sometimes reboots. Also happens when I am in 'Safe' mode. Anyone have any suggestions?
