nook color honeycomb. need HELP!!!!!
CB7Junkie
16
I have followed all of the steps to installing honeycomb on a sd card. but when i open winimage and under ?Disk? choose "Restore Virtual Image to Physical Drive." my sd card flash drive does not show up in the box. nothing shows up in the box. what am i doing wrong. please help. im so close that i can taste it.
Had that problem for myself for a moment..
Be sure to choose the option to view all files instead of the default
i dont even get that far. when you click disk it gives you the option to choose restore virtual image to physical drive. when you click that a box appears and it should have your disk drive listed there. in my case nothing is listed there. what do i do???
Winimage will not recognize my sd card. When i click "restor virtual image to physical drive" a box pops up that is supposed to have my sd drive as an option. There is nothing in the box and i cannot find help anywhere. Someone please tell me what im doing wrong.
Did you format the card as FAT32?
How are you loading the card? (ie... sd adapter going into the computer, micro-sd card reader.......)
Does the computer see it in windows explorer?
im running windows xp. it is formatted to fat 32. i am using a micro sd card reader and my computer does recognize it as a sd card.
Is there an option to "run as admin" in XP. It's been so long since I have used XP I can't remember. Try running WinImage as Administer?
What size card do you have?
Winimage and your SD
You may need to use diskmanager in Windows to change the drive letter or alocate the space on the SD card.
I am having this exact same problem. When I click on the write button along the top, it goes for about 3 seconds, then stops. Frustrating.
Edit: try running as adminstrator. Seems to be working for me now. Thanks for the tip above.
Right click on the file you want to run. Choose "run as" and then you'll get the the option to "run as user". Choose administrator.
ok. i fixed my problem. i just had to use a computer with windows 7. now how do i get the market on the nook with honeycomb???
tuovst
