Nookie Froyo Problems
kcls
901
307
63
So I just followed the stickied instructions on installing Nookie Froyo on my SD card. It worked and everything, but I just have a few problems. When I unlock, is shows a really small (Phone Sized) screen to unlock (Pic attached). Also, the notifications bar is really small (Pic attached). The "Softkeys" app wont work. I assume that this is what simulates the menu, search, home, and back keys? Any way to fix these things?
Thanks!
Thanks!
I have never used nookie froyo but I do suggest using CM7. Gingerbread > Froyo. CM7 has been completely optimized for the nook and has a very strong development team behind it.
Yeah, I just finally figured everything out earlier today... I'm using the latest stable build of CM7. Yeah, I know, nightly builds are better, but I don't want to mess up my nook or something. Plus I don't need all these cutting edge features. Maybe if it made the market downloads faster, but otherwise no. Market downloads right now are SLOW. It's easier downloading them on my phone and transferring them to my nook using Titanium Backup. Probably my class 10 Patriot 8gb sd card. I heard it had problems only AFTER I bought it, so I guess I'll just have to stick with it. Oh well.
davidlmcshane
