Not charging/reboot problems after rooting S6 edge
tannin52
I really need some help. So I tried to root my device to have android N on it. I used odin and applied the Kernel for the at&t version and it said it succeeded. I unplugged the phone from my computer and it started to reboot. But it stuck in the reboot screen which i heard was normal. It didnt reboot again and again instead it just stayed on the "Galaxy S6 edge: powered by android" screen forever, i was able to get into recovery mode by holding the home button, volume down, and power, and when it went black for a second, taking my fingers off the keys and then holding the home, volume UP, and power button. I tried wiping the cache, doing a factory reset, i went through basically everything but whether clicking on reboot or shutting it down and starting it up again the "Samsung Galasy s6 edge: powered by android" screen stayed on. So i left it on and the phone died, now when i plug it in for the first 10 or 15 minutes the grey oultine of a battery with a lightning bolt comes up, but after a bit it starts turning off and then on showing the device isnt getting enough juice. I saw that being stuck in a reboot was normal but im not sure why this happens. I have a backup phone (S3) that i can use to call people but i would really like to get this fixed. The phone itself is in good condition its JUST the software.
You might've flashed a bad, incompatible, or wrong kernel. You will need to reflash your phone.
  1. Plug in your phone for 24 hours, to see if it charges. If so, then move on. If not, remove the battery and charge it with a smart charger. Then reinstall it, if it was removed.
  2. Reboot into download mode.
  3. Try to flash again.
  4. If the phone works, you are done. If not, repeat steps 2 and 3 with different files. You might've flashed a bad one.
Untalasso
