- Apr 6, 2011
- 798
- 15
- 0
This is just something that started happening pretty recently (like, within the last week or two); up to this point, it had been working just fine.
Anyway, the problem is, it won't clear apps out of my "Update" list. Whenever I download the new updates, it seems to try to install it twice; I see in the notification bar, it'll say "Installation complete", or whatever, but it still brings up a menu for me to manually install it. If I manually install it after the notification says it's already been installed, I get an "Installation failed" screen.
I'd imagine that, if the notification bar says the install was completed, then the update was applied, but the Amazon App store won't remove said apps from my "update" list. They all still show as requiring an update... Anyone know how to fix this? This is getting pretty annoying, and my update list is getting bigger and bigger because everything that needs to be updated is still showing up in it, even if I already updated it... @_@
