Note 1/2 to connect to a serial port
mikee_qt
I don't know if its possible. I'm getting my note 2 end of the month and i was wondering is it possible to use putty or telnet with note and connect the note to a serial port? (for cisco routers)
I know its possible to buy a usb cable from note. then a usb to serial converter/adapter. then a roll over serial cable to connect to a cisco router.
my question is will this work? will the note think of it as a serial connection? or will it connect? I hope i make sense
Aruz530
