Note 10+ FPS won't work when it's wirelessly charging
  • Start date Start date
A
Android Central Question
The FPS for the Note 10 will not work when the phone is being charged wirelessly. Anyone else having this problem? Is it just my phone? I tried googling similar issue with the s10, since they use the same sensor, but I haven't found anything. Has me kinda worried that it's just an issue with my phone.
Mine works but not as well or lets say not as sensitive as it was. I made a thread on the S10 series forum and i get mixed replies.
Sometimes it does, sometimes it doesn't for me. But occasionally if I'm trying to unlock it while on the wireless charger, it tells me to remove the phone from the wireless charger to use the fingerprint scanner. So I'm assuming it's a problem they know exists. I am finding since my Smart Lock settings should allow me to access my phone without unlocking it in most cases, double tapping the AOD screen has been the easiest solution. But that brings me to a Lock screen that I have to swipe up on. It's a bit cumbersome. Not sure why they set it up this way.
Mine worked fine while wirelessly charging in my car/phone mount.
richardschofield
