Note 10 or Note 10 plus
Honestly the pricing ... I prefer smaller phones and while the 10+ is indeed a ginormous beast, after playing with it for a bit I feel I will be able to adjust to the size within a couple of hours of using it. When I got home from Best Buy and started playing on Samsung's site, the price difference between my Note 10 order and the 10+ order was $204, and I was getting more accessories with the 10+ order. So, I figured I'd sacrifice my preferred form factor to get more accessories, bigger/higher quality display, beafier battery and the added camera perks for only $200 more.
Awesome thanks for the answer. I've been wanting a smaller phone for a while but everytime I try one it just doesn't suit me because I start missing my note. So that's the only reason I went with the smaller one. I want it to fit more comfortably in my hand :)
Baby note :)
I still think I would have preferred something between the 2 size-wise. (Usable) screen a little bigger than the Note 9, and overall size a bit smaller than the 10+
I ordered 2 Note 10+. One in white for me, and one in black for my husband. It'll be his first flagship phone since he's always gotten my hand me downs since the Note 3. It's about time he has his own. Delivery now expected on Monday, the 19th, by end of the day.
I was worried about the Glow as well. It looks good, but I thought it might be too mirror looking, so I went with blue as well.
I went with the Note 10+. While the 10 is a good size, the 10+ is the same width, and only slightly taller than my XS Max. I was also a little worried about battery life on the smaller model.
Just an FYI, the Note + is over 11mm wider than the Note - and in the phone world, that is a big difference. The regular Note 10 is almost identical in width & height to the Pixel 3a and even thinner.
I'm not too worried about the size of the 10+. As I said, it's really close to the size of my XS Max, just a little taller.
I keep checking the shipping apps because I preorder through Best Buy. I have a feeling I will see activity there before the Best Buy app but I'm not sure. First time ordering through them.
I feel the same, its only very little difference in my s8+ and the note 10+ in actual size, the note + of course has larger screen display.
The figure you're we quotingis wrong. The difference in width is 5.4mm(77.2-71.8)
What a lucky man he is!
A few weeks into owning both versions I love and prefer using the standard 10 most of the time when out and about but the battery whilst not terrible is a step down from the plus model and does need managing.
I'd have taken a slightly thicker device to fit a bigger cell.
panelexchange
