Note 10 Wallpapers to Hide Camera Hole
What's the problem? Mike is way too high. It's like that for all of them that are designed to fit around the hole.
Here is one I've used for years. Works great on my Note 10.
Incredibles
When you press and hold the screen and select wallpaper from the gallery not from the app, there is a choice to activate motion is already active click on it to disable and then go to WallPix app and select the wallpaper you want, hope I was clear.
@Katrina White1
@Katrina White1
Yep, crystal clear. I'd have never figured that out. Many thanks!
jenleasch12683
