Note 3: Annoying LOUD AT&T start up sound
pounder001
681
12
Fairly new GN3 user: I have looked around but could not find any way to turn down the annoying very LOUD AT&T start up sound chime every time I turn on my GN3 :mad:
I am sure it is something simple to be able to turn down or mute it but I guess I am missing it :(
Any help would be appreciated - Thanks
Re: Annoying LOUD AT&T start up sound
Hello
Are you talking about the AT & T sound/screen during the bootup of your device? If so then no you can't do anything about that " stock ". Your device would need to be rooted to modify that.
I would assume (if available) that it would be under Settings > Sounds but i honestly forget what the default TW menus have (I have a custom ROM on my Note 3).
I use the app "silent boot" from the play store to silence boot up sound. This app doesn't require root. I haven't tried it on an att variant but it worked on my Verizon Samsung Galaxy Note 3.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Perfect thanks!
Silent boot worked. Thanks
Sent from my SAMSUNG-SM-N900A using Tapatalk
You don't have to root it to get rid of the sound. Settings - Device - Sound - Volume - System (turn that down) and then when you reboot you won't here that sound.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
Silent Boot didn't work for my Note 3 from AT&T. Even with the first TWO boxes checked. Neither did the Volumn > System. :mad:
My new AT&T N3 worked perfectly with silent boot? I wonder what the difference is
The boot chime on my Note 3 changed this AM. I haven't changed anything. Could this be part of the KitKat upgrade?
No that was not the boot chime. It was ...
The Wifi connect(ed) alert. And that is new.
Silent Boot worked perfectly on my AT&T Note 3
What else does silencing "system" silence besides the ATT boot music?
You need to root your phone buddy, Cause i found that very annoying to. Then download wanam app to turn it off.
Silent Boot was the answer for my HTC One X plus. (Android 4.2.2)
First of all it didn't work but then I turned off the Fast Boot option (Settings...Power...Fast boot) and it worked fine with only the first option ticked.
Thanks for the Silent Boot app tip, that is what I was looking for. I don't mind the death star but come on, pay up to Disney to get the music to go with it.
dear sir
i would like to start samsung g 130e model and to know the full details how to use this model for i am a senior citize n of 65years old please explain to me in simple language
thanks and regards
Thanks! Great suggestion. App worked perfectly on my Samsung s6 Edge. AT&T sound startup is gone.
odubstunts
