hello,
I got Galaxy Note 3 (N9005) just two months back from Ebay. It was working perfectly since today morning I charged to 86% and unplugged it usually using 2.0 cable to charge the device but now its not powering UP, tried to unplug the battery , sim for several minutes but still the same issue
After plugging the charger again its vibrating every 3-4 seconds and showing battery with grey color and O written inside it after it a wrecked line showing at different points that's crossing the screen just like screen is damaged or OS is boot loop
Trying to power on while the charger is plugged it just show Samsung NOTE 3 screen and sometimes samsung logo gets load with blue LED continuously onn again the battery charging issue
youtube: chvRbwgT9n8 or U5B2By7fGII
but it does not show green battery any more
since its not starting up and only shows activity when its plugged in USB/Wall charger , unable to use it. is there any resolution on this most of the Note 3 users are complaining about the same issue
tried to boot it in recovery mode and restart the device from there but still no success
this issue is occurring for the last 3 hours and i am really annoyed how to resolve this issue
tried USB 3.0 as well with laptop but no success even after 30 minutes
if the battery is drained it should start with the charger plugged in but it isnt starting any more.
**Update
plugged on wall charger
started the mobile with Volume Up+ Power + Home key
erased to factory reset
wipe cache
rebooted
now its passing the samsung logo , annimation and then white Samsung Logo blinking with colors and after that again same battery showing
no custom rom installed on stock version i think its 4.2.2
It didn't worked out, same issue with a new battery set is not starting with Battery Power only starting up with charger plugged and giving the same battery sign
**Update
wipe cache
rebooted
