Note 3 Lags sometimes and is slow here is how to fix it!
society187
5
my note 3 was giving me problems in the transitions and opening photo gallery stuff like that but here is a video showing how to fix it hope it works for you like it did with mine! :)
i am at work, right now, and work computers can not let me see videos, i hope to see this as soon as i get home tonight. thanks in advance for the video.
This is brilliant. Thanks man
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
this is the first thing I do on any new phone but I could not find the developer options. Thanks for sharing, Very Helpful
How do you make your dock look like that. And how do you access St voice if you shut double click off?
Posted via my Galaxy Note 3
Looks like he is using Nova Launcher.
Open S Voice (double tap Home Button or open from your app tray)
Press the Menu button
Select ?Settings?
Check ?Wake up command?
Turn ?Voice wake-up? On to activate S Voice even while the screen is off!
Select ?Settings?
I figured that was it. I feel like a tool saying "hi galaxy" I keep that off.
This is a close fix... but you have to have your screen unlocked first.
1. Settings
2. Device
3. Lock screen
4. Wakeup in lock screen
5. Record voice
Or I can just add the app short cut to the home screen. LOL.
This is awesome and worked perfectly, thanks! I noticed that the lock screen lags when pressing the home button to unlock (I don't use any security swipe or pin), do you ever experience this? If so, anything to help fix?
Thanks!!!
For those who prefer written instructions :
Get rid of slowness when pressing home button by disabling S-voice via home key
1. Double Tap the Home Button
2. Menu
3. Settings
4. Turn off Open via Home Key
Disable animation
From Home screen:
Menu>Settings>About this Device
-Click Build number 7 times.This will enable Developer options.
-Go back to the Settings main menu and Select developer options
- For "windows animation scale", "Animator duration scale", and "transition animation scale", select "Animation is off".
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
That was great, thanks a lot! I am using Nova and had already got rid of most of the stuttering, but with this trick, it's just as responsive as a nexus device!
Sent from my SM-N9005 using Tapatalk
This has broken daydream animations, even after bringing those settings back to normal and rebooting my phone. Anybody else suffering from this? Any ideas how to fix it?
I relied heavily on daydream, but it's pretty much useless without animations.
What is daydream?
What is daydream?
An Android 4.3 feature that allows for apps to show on screen while the phone is charging or docked. I used to use dash clock widget a lot, very useful to see all that info without even touching the device.
Ok so first I t was introduced with 4.2. It is one of the things that has annoyed me about the Nexus 10. It is a great feature and no dock to take advantage of it.
The best way to explain it is a built in sleep mode for a device when it is plugged in. The example the person above gave is a great example. Since 4.2 was released there are some cool clocks and widgets for day dream mode.
The catch is what day dream really did was provide a way to customize this functionality in android. Samsung has included a dock mode for a long time. I used it allot on my OG Note. It worked great and functioned as my main alarm clock on my OG Note.
With that being said I think the Dock Mode setup disables daydream.
lindbo10
