Note 3: Pen window compatible apps. Non rooted devices. Help compile!
Re: Pen window compatible apps. Non rooted devices. Help compile!
Outliner Professional version 1.4.0 works with the Pen Window
Meeting Minutes Pro didn't work in pen window. Are you sure you don't mean a different app?
Added 2 new browsers. ..Puffin and Naked.
My version of Meeting Minutes Pro, By Sriman Apps Version 28, release 3.0 works just fine. I just finished a meeting with my boss, took notes in Meeting Minutes Pro using the pen box, synced them so they are available on my Tab. Are you sure you are on the Pro version, and using the latest. BTW, I have a Verizon phone, could there be a difference in the Android Builds?
I believe I tested the same app, not sure about the version # though...could be the branding...I'm on Sprint.
I'll be getting one through Verizon soon and will test it.
Have you tried Papryus? On my phone it crashes, sometimes, in pen window. ..particularly when I try exporting to Google Drive...very curious if it works on yours!
News+ no longer works with latest update.
Great news...These pen window apps work in Kitkat 4.4! Update also ads a few to the default menu (which is now editable) as well as adding a blue frame to pen windows!
Better yet there is no more bugs when exporting to Google drive from within pen window apps like Papryus!
Gmail, deliveries package tracker, friend caster. These are other ones that work not sure if they are already listed.
Posted via T Mobile NOTE 3
Thanks heather_dunphy!
Added them to the list.
I also added what I learned about how the kitkat update handles this trick!
I am using Exynos version and it seems Whatsapp is gone in pen window after the Kit Kat update. Anyone else have this issue?
Hi All,
When i go to the Google play in "my apps" section i only have button "Installed". How do you achieve to start those applications?
Regards
Everyone here must take a look at the Floating Window Shortcuts app. The app makes the pen window supported apps directly accessible from the notification bar but not only the Samsung's supported apps but every app that can be opened with floating window is now accessible from the notification bar which makes it more easy and useful. I suggest you guys take a look.
https://forums.androidcentral.com/e...ating+window+shortcuts+android&token=NVte5s-w
dokan nice tip!
I am about to add aeon's app to the original post... MW-Pen enabler.
This tool will make MANY new apos compatible with Pen Window!
I use MW pro and have added a few. It routinely crashes though, so it still needs a lot of work.
Via my Note 3
fusionrobes
