Note 3 vs Note 4 Reception
orporter
18
I was in the Verizon store near me where the reception is strong, tower just down the road. My Note 3 which has weak reception compared to my Note 2 and my wife's i phone 5 and now 6, read -101 in the settings. The Note 4 showed -102. These are both almost weak, 3 bars, must be same radios. I am a little concerned that they did note bump up the reception on the new Note 4.
As long as there is no signal loss, it doesn't matter much.
Sent from my SM-N900V using Tapatalk
I guess I was hoping for better reception on the Note 4. My Note 3 does not have good reception at all. Love the rest of the features and the screen but as a basic phone it is very weak. I will be interested to hear how the Note 4 performs. If it is indeed better or as good as my Note 2 I will pick one up.
I just up-graded to the Verizon Note 4. First impressions. The reception is much stronger on the Note 4. My Note 3 was awful after the upgrade, period. Nothing I did or Verizon tried helped. My reception out of the box, in my house, is -84 dBm, the 3 never came close to this. My Note 2 had this same kind of performance. I am very pleased with this so far. Hope it holds up. I was tired of having to go where T-mobilers went to make calls at my place of work. I like having a smart phone but I also like having a phone that can make calls where it should. Reception is important as these devices advance.
As reception improves battery life declines. It' s just an algorithm. You want max reception go moto or iPhone
I believe you meant just the opposite. When reception is bad, the phone works harder trying to find and keep a signal, which eats up more battery.
No, I meant what I said. My Moto gets reception where my Sammy doesn't because it works harder to get the same signal. I took a class in the basement of a building where the Motorola drained from full to 50% in 2 hours and got hot even though the screen wasn't on. My Sammy would drain about 10% in the same time but it lost the signal. The signal is the same no matter what device receives it.
My Note 4 is performing on par or better than my wife's iPhone and so much better than my Note 3. I can make and receive calls in known weak areas. Like I said or tried to say. I am sold on the Note 4 and the reception it is giving me. Sounds like you two are saying the same thing as far as battery life and trying to lock on to a signal. My battery life is great on my phone so far, even in tough areas, I get through a day and have battery to spare.
The note 4 is way better in weak signal areas than the note 3. The dbm might be similar, but the note 4 gets better speed tests even at the same weak signal.
And even though the note 4 gets better signal, in my usage it doesn't drain the battery as fast as the note 3 in the same weak signal area
Sent from my Verizon Samsung Galaxy Note 4
Are both devices on the same band?
You want reception buy a Motorola (not nexus) or an iphone. You want features buy a note 3.
mostafamu
