Note 4 and Call Recording
Just a heads up, Automatic Call Recorder by Appliqato works perfectly even on speaker phone and even while using a Bluetooth earpiece. I tested using my Samsung Galaxy Note 5 from t-mobile on the latest software version LMY47X.N920TUVU1BOH6 and baseband version N920TUVU1BOH6. The latest lollipop 5.1.1.
AllCallRecorder also works again (by far the best in my oppinion)... upgrade to Lollipop 5.1.1. simply has fixed the error (and maybe a lot of other errors in 5.0.1)
This thread just ran off the rails, and did answer the guy's question.
Answer: Yes, you can use Total Recall to record conversations on the Note 4 using Android version 4.4.4. No problems.
None of the recording apps mentioned work with my Note 4 on T-Mobile in AZ. :(
Will rooting make a difference?
Common Law - You can record whatever u want. Particularly if you have suspicion, and is investigating. No point telling a criminal that you are recording him/her.
We are being recorded all the time most everywhere.
Automatic call recorder stopped working on my Note 4 when I upgraded to Marshmallow 6.0.1
Tried other recording apps, also stopped working, thanks Samsung.
My automatic call recorder app still works with Marshmallow. I have Verizon.
Try FonTel - Call Recorder app. It works on S5, S6 and Sony Z3 with Marshmallow so maybe on Note 4 too.
smith-jhone
