Note 4 battery
pre1561
199
For the last few months I have been having a lot of problems with my Note 4 battery. It doesn't last more than 2 or 3 hours. I'm on the Sprint network. I have a new battery, and have scanned the phone with CCleaner, and 3 different anti-virus apps. They have not found anything wrong. The tech at Sprint told me I might have to do a factory reset. But I don't know this tech, he is new, so I don't know if he knows what he is talking about. I have stopped all of The running programs once, but of course they re started. I think I might have a memory leak somewhere because the main memory is low. The phone has a hard time downloading app updates and anything else I try to download. Everything has slowed way down. Thanks for any help/advice.
Sent from my SM-N910P using Tapatalk
There seems to be alot of problems with the Note 4 battery.. (including mine)... started shutting down at 30%.. then 40% .. now randomly shuts at 80 or 90%. Have tried altering all the settings... finger is pointing to the FAST CHARGE with these batteries. I have not yet confirmed if this is a inherent issue with fast charging.. I would suggest NOT fast charging your phone... and i would try deep discharge a few times .. i will be trying this myself. Hoping ofcourse the battery isn't already FUBAR'd.
That's odd. Did you get an original battery?
Mine still staying on at 9%..
Not sure what you mean by 'ordinary battery'. Its the battery that came with the Note 4 and fast charger rated at 3220maH with the NFC antenna built in. Part # EB-BN910BBE. The problems only started occuring after about 10months.
Here is an interesting observation... My battery today died at 80ish per cent. Put it on normal charge (not fast charge) ... unplugged and removed the batteryat 48% .. put it back in... turned it on and it.. now showing 98% ...
When the phone "dies" at a good amount of battery capacity (nothing under 40% - you should NEVER discharge any lithium battery more than that), go to the battery graph,, tap on the graph and look at the second graph you'll get. Is there a sharp drop to 0? If there is, the battery is growing a dendrite, and there's nothing you can do but replace it. (See Lithium Battery Dendrite links.)
That makes sense although one would expect excessive heat generation with dendrite discharge... also noting that removing the battery and re-inserting brought (android reporting) the charge back up to 98%. Replacement batteries with NFC (supposedly genuine from Australian source) are selling for A$20... at that price not worth fluffy around with a fix with the battery that came with the phone. Yes, this happened only with the battery that came with the phone there has been no replacements. Must look into the Dendrite causes.
A thin dendrite burns out so fast there's not enough heat to raise the battery temperature.
True. Most replaceable batteries are cheap enough to not worry about replacing.
You, the entire automotive industry, and over USD10 billion to date. They haven't come close enough to get ideas of what to look for yet.
Wcoatwhowma
