Note 4 Screenshots! Show use those awesome home screens & more!
Swipe right for mail, then calendar. Swipe left for apps.
Wish I could figure out how to remove the "updated...." statement about the weather. Browsing weather widgets.
There might be a setting. I use HD Widgets and nothing like that there.
via Note 4 on Verizon Wireless
Can somebody please point me in the right direction of how to put wallpapers on this phone and have them look as clear as yours guys does. Every time I set one it ones of the zooming in and has this weird, panned, look to it. Even with a 2560x 1400 photo
Take out the PEN, press screenshot, share.
Found a few that work...this is what I'm working with now. My ocd is killing me that the flashlight doesn't line up with the other three lol
That's strange...are you using a launcher? if so long pres and try re sizing or moving icon I have not seen this happen before. I would not like it either.
If you are not using a launcher I suggest nova prime...works great and I've never had an issue like the icon one you have unless the icon needed to be moved or was on overlap mode in nova.
The picture I have is supposed to be like that....
What I'm talking about is let's say I download the pic, and set it...when I go to my home screen it appears zoomed in on and pixelated. The half joker face is the way this pic is intended to be.
is the flashlight a widget?if so,that is why it would be uneven.
Youre the man lol
Youre the man lol
I was not talking about the joker but about the flashlight icon...I didn't know if it was a widget or an app. If you are using a launcher you may be able to resize it or overlap it so that it is even with the rest of the icons. As far as wallpaper goes you could try an app called image2wallpaper. Hope you find what works.
Oh...yea, someone mentioned if it's a widget it won't allign...it is indeed a widget. I'll check that app out...thank you!
wmorg
