Note 4 Screenshots! Show use those awesome home screens & more!
At it again lol! Vintage icon pack with a zooper clock.
Trying Out Zooper before changing the wall... having trouble finding Zooper clocks or weather that I like. Order is Left Center Right.
New zooper widget
Re: Note 4 Screenshots! Show use those awesome home screens & more!
Trying to get a larger image here. This was posted via the forum app. Last one was with the ac app
I need those widgets lol especially the battery one!
The battery widget is called Minimalistic text. Another cool widget with many customization options. You should check it out, you will like it
The weather widget is called xwidget. Very cool widget as well with many pre existing themes/skins. The clock of course is Zooper
Awesome minions layout! Can you please share the wallpaper, clock, battery meter and icons in post #1127? Just the whole layout pretty much. Lol.
Attached is the Wallpaper and the minions PNG file which is a zooper widget. The clock is also zooper widget and the battery is minimalistic Text widget - https://forums.androidcentral.com/e...tails?id=de.devmil.minimaltext&token=ILK3WWHU
The icons are called devo, found here https://forums.androidcentral.com/e...ls?id=stealthychief.theme.devo&token=XMRIB7mo
The weather widget is xwidget with a custom made skin/layout - https://forums.androidcentral.com/e...ils?id=com.xwidgetsoft.xwidget&token=yj-cEEos
Oh ok, I had dl minimilastic text free one but haven't gotten around to mess with it yet. Next stop, xwidget!
My latest Homescreen.
Sent from my GNote4 using Tapatalk!
Xwidget is a good widget, lots of skins. Not the easiest to customize but does offer the option to. I mainly use it with built in skins and make my own edits to them rather than create them from scratch. There is a PC version that lets you create the skins on the PC then import them to Android.
Came across another wall that I dug so changed again. HexaPulse icon pack, zooper clock. The icon pack is free so doesn't have a lot of icons but had what I needed.
Alright, acclimating to Zooper quickly! Love the iPod widget, works with all my different music services (Spotify, Pandora, SD Card, Milk). Order is left, center, right.
Where did you find the ipod widget? That's awesome. Lol
Edit :I found it
dumpsterrentals89
