note 4 system ui problem?
richhb
Just purchased a Note 4 a couple of days ago straight away it requested an upgrade to lollipop which i did however today the phone just came up with the message [ Unfortunately, System UI has stopped ]
i went into the application menu and cleared the cache in the system ui, and it did nothing so i did a battery pull which seems to of done the job
i am just wondering what is this problem? is it because i update the phone to lollipop was thinking of doing a factory reset and not updating to lollipop?
any help is appreciated.
Rich
If it doesn't happen again, it may be a one time glitch. Didn't see many others out there reporting this problem with a Note 4 and Lollipop.
What I've seen recommended after an update is a factory reset. Factory reset not just for the Note 4 or Lollipop, but other Galaxy devices. I didn't do a factory reset after updating my Note 4 to Lollipop, and so far no problems.
If you continue encountering problems, a reset may be an option to consider. Just be sure to make a backup for all data on your Note 4 that you don't want to lose as the factory reset will wipe out data.
http://forums.androidcentral.com/sa...date-need-factory-reset-after-installing.html
I'm also experiencing the UI system problem thing. It's just suddenly appeared on my screen. Then I noticed that I can't easily upload pics on fb. My phone is note 4.
