Note 4 Wireless battery charging and another case
browetally
108
I currently have a Note 3 but just pre-ordered the Note 4 from AT&T. I'm interested in adding the wireless charging feature as I've never had it. On my Note 3 I use the Incipio DualPeo case. Can you use this type of case and have the wireless charger back cover?
Re: Wireless battery charging and another case
A lot of cases are too thick for the wireless charging cover to work. I've researched this a lot, and from what I understand, the spigen cases usually work well with the wireless charging. Hope this helps.
I have wireless charging on my Note 2 and it is simply a coil that slips under the back cover. It makes the phone just slightly thicker and the back cover is a bit rounded. With the cover on it is not noticeable.
You'll need either the wireless charging receiver or the official wireless charging back cover. I had the receiver in my Note 3 but noticed sometimes the phone wouldn't charge unless I had the phone perfectly on the pad. Now I'm using the Samsung wireless charging back. I noticed I didn't have to put the phone on the charger exactly for it to start charging. Downside is most cases do not fit with the Samsung cover since its thicker.
I also use the universal QI wireless charger that Gator352 mentioned above on both a Note 3 and S3. It works great and the coil is very thin, so it should fit inside any back.
Heard a lot about wireless charging. What are "all" the required accessories for the note 3 or 4 wireless charging?
I used to get the Fat battery to last longer
but once I tried wireless wooohoooo it rocks
I carry a extra battery that last me full day
I also have the Extra battery kit
wish Samsung doesn't delay the wireless cover for 1 month like always
that sucks a lot :(
the good part is I can use all different back covers
witht the thick battery we could not lol :p
I have S5 now... waiting for the Edge ;)
Samsung Galaxy S5 4G LTE Qi Wireless Charging - YouTube
romanjona
