note 5 vs note 5 edge
mgm83
110
So what will be the differences? If they are the same screen size and same internals I might opt for the note 5 edge this time around...
It would seem there is no note5 edge that slot is taken by the s6edge plus
So your saying the Note 5 edge and the s6 plus will be the same phone?? I'm trying to find the deference between a note 5 and a note 5 edge.
There is no Note 5 Edge, to follow up the Note 4 Edge. Instead, they are releasing a larger S6 Edge via the S6 Edge Plus.
Here :
Galaxy Note 5
• Display: 1440x2560 pixel Super AMOLED*
• Processor: Qualcomm Snapdragon 810 or equivalent EXYNOS
• RAM: 3GB
• Battery: 3220
• Front Camera: 8-megapixels
• Back Camera: 13-megapixels (similar/same sensor as Galaxy S6)
• S Pen: Yes
*Could also be 4K - both displays have been tested.
Galaxy Note 5 Edge
• Display: 1600x2560 pixel Super AMOLED
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
Here :
Galaxy Note 5
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
Galaxy Note 5 Edge
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
Everything indicates that there will NOT be a Note 5 edge. Zero indication. There is only supposed to be the regular Note 5. There will be a larger version of the S6 Edge unveiled called the S6 Edge Plus. It's just a larger version of the standard S6 Edge with, most likely, a larger battery. There should NOT be an S Pen in the S6 Edge Plus.
Wouldn't it be a Note Edge 2 instead of a Note 5 Edge, since the first one was called the Note Edge?
Here :
Galaxy Note 5
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
Galaxy Note 5 Edge
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
These specs are rumours. I wouldn't believe any of them especially since you are listing specs for a phone that doesn't seem to exist.
yea so far there have been no leaks or indications of any note 5 edge it all points to the s6 edge plus filling that spot and just a regular note 5.
There is only 2 phones coming out
- Note 5
- Galaxy S6 Edge+
There is NO NOTE 5 EDGE
Here :
Galaxy Note 5
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
These specs are so wrong.
First the back camera is 16MP not 13
Second the front camera is 5MP not 8
Third the RAM is 4GB not 3
Fourth the battery has been rumored at 3,000mAh but GSMarena posted that it'll have a 4,100mAh
Fifth there will be no Note 5 Edge and hence why I didn't include that in your post that I quoted
S6 Edge Plus looks nice, but if its stuck with 32GB of storage forget about it (as rumored).
Here :
Galaxy Note 5
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
Galaxy Note 5 Edge
• RAM: 3GB
• Battery: 3220
• S Pen: Yes
I heard note 5 would have 4gb ram?
imun
