Note 7 Accessories Compatible w/Note 5 &/or S7 Edge?
Status
Not open for further replies.
souffoue
117
When I got my Note 7 I purchased the wireless charger, a case and a car charger. So that was approx. $100 that was spent on accessories. I am out the case I know for sure which isn't that big of deal at about $20. But the wireless charger was $50 and the car charger was $25. Does anyone know if the wireless charger and car charger for the Note 7 will work with the Note 5 or the S7 Edge? I'm leaning towards the Note 5 as my "downgrade".
Thanks for the help!
The wireless charging is good for anything that supports the standard that you got. The car charger, however, I'm guessing is USB-C, so as long as you can use different cable or have a microUSB adapter, that's fine. If not, that's a no-go.
Also, AFAIK Samsung and carriers are offering to refund any accessories purchased. Just don't know exactly how that works.
Re: Note 7 Accessories Compatible w/Note 5 &/or S7 Edge?
The wireless charger will work because I bought one for my note 7 and it works fine with my S7 edge.
Amazon is also offering returns for Note 7 accessories, even if its past 30 days. You'll need to talk to them via online chat.
Thanks! That's great to know! All my accessories (well, case and screen protector) are from Amazon. This will make it easier.
Yes, depending on where you got your accessories, as long as you return them with your device, they will refund you for everything. I don't believe they will let you do them separately, at different times.
This is mostly true. I have 2 cases that I bought thru Amazon that were shipped and sold by Caseology and Ringke. The rep sent them an email on my behalf requesting return label. So far only Caseology has replied and they have denied the refund because it's been over 30 days but did offer me a replacement for any phone. So there's that I guess.
Status
kiki2025
