Note 8 Charging - Will the Note 7 chargers work
tntiger
52
I still have all of the Note 7 accessories and wonder which, if any, will work with the Note 8 - especially the charging cables.
Thanks!
Did the 7 have USB-C? The other stuff should work, but I'd check the current on the chargers just in case.
I discovered that the Note 7 Stylus works on the Note 8!!! I had an extra Note 7 Stylus left over and kept it for sedimentel reasons. Well i tried using it on the Note 8 and it worked!! When I compared them side by side they almost looked completely identical. The Note 7 stylus fits perfectly in the stylus holding slot on the Note 8!
My Sammy Note 5 charger fast charges the Note 8. Though not all cables show fast charging.
The chargers from the 7 work fine. I'm using the white Samsung Fast Charge I got when I got the 7. I'm using the Samsung Fast Adaptive chargers I bought for the Note 4 with the adapter, they work well also.
PmGs
