Note Edge mmc_read failed
zigaliro
54
Hey,
so I tried to root my Note Edge and it didn`t work out, I crashed my phone, so I had to do a factory reset in recovery mode, but now after that my phone started to restart every 10 mins, very annoying, then all of a sudden my phone turned off completely and I couldn`t turn it on for about 4 hours, now after 4 hours I somehow finally managed to turn it on, and I got this error: mmc_read failed. What is this? How can I fix this?
Oops.
mmc storage is the storage in the phone. Try (since you lost everything with the reset) flashing the stock ROM.
If you still have mmc errors, it's probably a hardware failure.
Oops.
Well, I tried to flash it using this guide. My model number is SM-N915FY, the same as in this guide, so it should work, but it didn`t, it failed :/. This is the error I received in odin. This is the firmware I used.
Marlene
