Note pro issue
elvyb
74
Started having issues with my note pro. I have done a factor reset,I have wiped the cache,
When I first try and lock onto my home wifi, it has issues, my Samsung St has no issues, when I do get connected to wifi everything is lagging, different Google application keep stopping.
This has been a great device until now. I have never rooted.
I also get a warning that says I will not get updates due to changing the system.
And every time I log off my wifi will not connect it says check the a quality of my Internet. My other devices connect without a problem.
I also keep having issues of log into setting. When I try to log into setting I get a prompt that setting has quite.
To clarify, are you saying that during initial setup after factory reset (assuming you used the factory reset option in recovery, not Kies) you're unable to connect to your home wifi?
If so you may want to use kies to do a full reset. It could be that the system is corrupted.
Yes.
What my wifi says is check the quality of your Internet.
Assuming the issue isn't with your router I'd check to see if doing a full restoration using Kies would resolve it. If not there could be a hardware issue like a loose connection internally or something.
Sent from my SM-P900 using Tapatalk
Ertiotka
