Note4 problems with side key panel
JustinM99
4
After I updated to Marshmallow 6.0.1, I find out that my side key panel doesn't work properly. For examples, I can't manage keys, cannot choose which icons to be shown in the side key panel.
I also cannot choose its transparency as well.
Does anyone have these problems? Do you know how to fix it? Please help me
Thank you in advance.
Try clearing cache and data in EasySidePanel via Settings, Application manager, in the upper right select the three vertical dots and choose "Show system apps". Scroll down to EasySidePanel, select Storage then clear cache and data.
Thank you for your advice, however, I still can not manage the keys.
There is no button to be chosed in the manage key setting. TT
Same here. Unable to manage side key panel. Transparency dosent work, hide key panel option dosent work. It happened yesterday suddenly when I was installing an application from play store and while installing it, I enabled side key panel from notification panel and suddenly my mobile restarted. After the restart, my mobile settings were reset to defaults. Ringtones, notifications etc, everything was restored to defaults, like soft reset. Then I noticed that side key panel having issues. Anyone facing the same issues?
cinemacritic
