Notification LED color
Mariah Richardson
151
I noticed today that for my snapchat notifications, the LED is like a weird yellowish orange with a little sliver of green in it as well. This makes me wonder if the green isn't supposed to be there, since it's not a solid color. Can anyone tell me if their's looks the same? All other notifications look normal.
If all the others look normal, it's the snapchat app causing you issues.. Have a chat with the (snapchat) devs...
Hm, really? Do you know of maybe an app I could use to test my notification colors? It couldn't possibly be just the orange color of my LED having an issue? Lol sorry if that's a dumb question.
You can dial *#0*# to get into service mode and check out the hardware there. If they passed, that means it's software issue and if other apps work OK then you can narrow it down to the snapchat app...
In any case, try the hardware check to start with. :-)
Oh thank you! Just did it, the LED seems to be fine :)
Am having the same issue. Mine randomly stopped working. I never used any LED management software.
When I use the *#0*# code to test the LED indicator its also is not working. Did anyone manage to fix this?
The phone is just 18 days old :(
rfhouser
