Notification LED Light Bleed?
Does this happen on your s7 edge black?
  • Total voters
shadow82x
238
I'm really just nitpicking at this point, and I wouldn't ever return my device over something so minor. But for example, when you are charging your device, with the red LED active, do you notice some red light bleed where the body meets aluminum chassis? Other bright notification LEDs also make it easy to see. This is primary noticeable in dark environments.
S7 edge black
Have 2 silver and one black and do not see this on any of them. I even took a magnifying glass and could not see the bleed.
Voted No on your poll but it did not register.
I have no bleed. Was checking in a completely dark room with green notification and red with charger.
Ugh. Now its bothering me. Wonder if I should swap the phone. Grrr.
Tech OCD at its finest.
Decided to test out a new phone, same exact issue. I'll just accept it's not a big deal. Perhaps just a batch issue?
S7 edge black
It could be just your carriers model maybe?
No it's a batch issue, mine is UK based. Don't think it affects anything as I've had my phone underwater for photo testing and it's not died on me. Plus I can't see it with my case on. Suppose you can swap it if you really want to.
