Notification Led not working
ItsaRaid
613
10
Hello, I have a new OneX. The Notification LED is not working on email, text and plume. I get the.notification sounds, the.new.mail counter is working but not the LED.
Anyone have any ideas.
Okay, heres what I found out. If the Phone is plugged into the charger, it WILL NOT blink for a email or Text Notification. It works fine once your done charging.
This leads to the next question. Does anyone know of a app that does a better job of notification? Also the Notification on Plume is real finicky, it works but doesny. I have the LED set for Blue, but it doesnt work- the Bird Chirp works sometimes.
Do you have the option turned on? Settings> Display&gestures>LED notification.
Does your LED work (red) when you plug it in to charge?
Sent from my HTC One X using Tapatalk 2
the charge led.lights red.and.changes.to.green when.done. otherwise it won't work.for.text, email or.plume.
I just stick to the noled app the light on this phone is way too hard to see imo.
Sent from my HTC One X using Android Central Forums
I just stick to the noled app the light on this phone is way to hard to see imo.
I had to return my first unit because of a defect, and couldn't believe they even bothered with the notification light cause it was so dim and hard to see. My new one is incredibly bright and easy to see from across the room. It looks like the light on my new one is a lot more centered within the earpiece speaker hole.
It doesnt flash if you are charging it....its constantly on red for charging and green when fully charge....
RohitPatidar57
